I downloaded the new SDK with the hopes of simply adding the F6 variants to the build list for my watch faces; however, it seems the permissions have changed a little. Previously all of my watch faces had the backgrounding permissions set and worked without issue. On the new SDK it seems nothing will compile with this set, if the watch face is uses greater than 32KB, or at least that is what the errors are telling me. Is there a change in code structure required for the new SDK? All of my my existing watch faces won't run, let alone the F6 series.
