How to detect Activity?
hi everyone,
so I talk about watchface,
in the sim I use :
var loc = Activity.getActivityInfo().currentLocation;
if loc = null that means for me no activity, and for the code on the sim that works great!
but on a real device (mine is Fenix 5) that is not so easy, even if no activity, for the watchface, loc is never null.
(actually i don't need my position but i use the same var for sunevent etc.)
is it a bug? or is there a better way to test if an activity is playing?
have a great day!
  • currentLocation won't be null for a while after an activity has ended.  After a period, it will go null, but that could be in the range of hours.
    In a watchface, it won't be null at times even if you're not running an activity.
  • Thanks.
    In case it would help someone Else,
    I used starttime, it does not work on sim but works on réal device.
  • I'm trying to understand here.  You want the WF to know if you are recording an activity?  Best case, that could only happen with a native activity, and then, only if you aren't running any CIQ data fields.
    If an activity has a CIQ DF, you'll only see a native watchface while in an activity and go to the widget loop.
  • My objective is to get the currentheading on a watchface, and detect if an activity is running to trigger it.
    I ll have to start an activity like running and phold lowest left button to go back to watchface. With this I will be able to get Activity.Info for a watchface.
    Sorry about my English, do you see what im trying to do ?
  • Yes, you're in an activity and enter the widget look to see your watchface (at that time up/down with take you to the widgets) to see the heading
    But again, that won't work if there is a CIQ data field in use by the activity.
    It seems to me if a user wants to see the heading while recording an activity, they would just set one of the data fields to show that
  • I'll aware all the users about this CIQ data field,
    off course it will be easier to add a DF with this, but I try to use this technic for F3 user, (and cause it was requested too)
    since we can't have access to sensor due to its lower CIQ, with this I can display on F3 info like pressure, temp, alt etc.
    at least I hope so.
