Hi All,
Hope I can get some help from someone with more experience or the Garmin team:
Many times, after bluetooth loses connection (due to range) and then re-establishes the connection, when using Toybox.Communications.transmit(), the ConnectionListener returns with onError(), and the message doesn't go through.
Sadly this doesn't sort itself out and only returns to normal after switching the bluetooth connection off and then on again several times manually through the Settings menu.
Any ideas?
I've been struggling with this for some time, thinking the blame was on my Android app, but now I'm pretty sure the fault rests with the Garmin Connect infrastructure.
Thanks!
