Last battery charging time
hi !
is there any way for a widget to know when occured the last battery charging?
or do I need to use a background process to check on interval if plugged or not?
in that case It w'ont work for "old" models like F3, no background and no isCharging.
many thanks
  • With a background process and the fact it can run once every 5 minutes, it is possible to miss being plugged in for just a couple minutes.  Also, the charging status you can see in CIQ is more "plugged into external power" as it will stay true even if the watch is at 100%.
    In the past, I looked at just watching the battery level, and if it's going up, it's charging.  But that is really tricky, as during normal use the battery level can bounce up and down a bit (due to temperature, etc) so you have to look at "has gone up a certain amount" for charging.  The flip side is trickier, as when you unplug to want to know it's not charging, but if you're running a WF, that drop could be so little, that you could think it's charging long after the watch was unplugged.
