Developer key is not set
Trying to run the generated project, I get the following error: Error:Monkey C: Developer Key is not set. Go to Settings; Build; Connect IQ Of course, I did set a developer key in the settings. Tried both the DER and the DEM file, but the error remains. I am using openssl 1.1.1, Connect IQ SDK 3.0.12, IDEA 2019.1, Connect IQ plugin version 0.3.8. and Linux Mint.
  • When you generated the developer key, did you follow the directions in the Programmer's Guide here?  The instructions indicate that you should reference the .DER file. Have you tried generating a developer key from Window > Preferences > ConnectIQ > Compiler page?
    Is there anything else wonky about the path to the .DER file? Maybe spaces in the path? I ask because we occasionally see bugs related to spaces in paths.
