Build OAuth request in PHP
I am trying to retrieve a FIT file but am stuck structuring the request. I'm using PHP on a hosted Ubuntu server.
I have registered with Garmin Health API  and have a consumer key and secret, and a user access token and secret, and a callback URL so I should be able to retrieve the data, but I  have spent three days trying to build the base string to get a signature but all I get the I use it is "Invalid OAuth signature".
Garmin sends me the following JSON
{"activityFiles":[{"userId":"f3d251ed-e12f-470f-9589-3bcb8a49eda8","userAccessToken":"1033030f-5847-4d90-9e10-3bb7fe1e29f8","summaryId":"39092291772","fileType":"FIT","callbackURL":"https://healthapi.garmin.com/wellness-api/rest/activityFile?id=31174708306","startTimeInSeconds":1566006366}]}
I am unable to generate a successful signature and request header with the following variables:
$request = 'Authorization: OAuth';
$request .=' oauth_consumer_key="'.$oauth_consumer_key.'"';
$request .= ', oauth_nonce="'.$oauth_nonce.'"';
$request .= ', oauth_signature_method="HMAC-SHA1'.'"';
$request .= ', oauth_signature="'.$oauth_signature.'"';
I have tried using the PHP libraries recommended in the OAuth SDK doco:
"Note:Implementing OAuth signing manually can be quite complex. It is recommended that all partner integrations leverage an existing OAuth client library. A list of OAuth libraries that supposed OAuth v1.0 by language is maintained at https://oauth.net/1/."
but I can't get to first base on implementation as I can't interpret the user notes.
Has anyone used either of the PHP packages : "PHP OAuth client" or "OAuth component for CakePHP" ?
Top Replies
    Former Member +2
     what did you use to authentication process? I am trying to authenticate the user at the access_token URL but I receive Invalid Signature information after agreeing at the Garmin website. Everything…
All Replies
