I'm newbie with Garmin Developer.
I've Eclipse 2019-06 updated in a Ubuntu 18.04 with connect IQ SDK version 3.0.12. I'm trying to start Simulator and it do nothing.
Glad you were able to find this. We are looking at updating the lib so that we don't run into this on newer platforms.
I'm in the same issue with MacOSX can you detail your solution? Please
This is likely something completely different as the issue the other developer is having is unique to our Linux SDK. If you post some more information we might be able to help you figure out what is causing the issue for you.
Another user discovered that we have some issues on MacOS when using case-sensitive file systems.
You might check to see if the Mac you're on is using the default (case-insensitive file system) or not. If you're using a case-sensitive file system, you'll have to use the workaround mentioned in that thread for the time being.
