Backing out the Beta
For some reason., I can Build my CIQ data field fine for a specific device with the Beta, but I can't export to publish it. I assume that is an intentional feature.
So now I'm trying to back out the Beta and install 3.0.12 into Eclipse. But I can't install the 3.0.10 plugin (because a newer version is already installed). And I can't load the 3.0.12 SDK. The SDK wizard only sees the Beta version now.
What's the trick? I'm sure it is an easy fix.
  • I think you should be able uninstall the plugin, and then you should be able to install the 3.0.x plugin, and the 3.0.12 SDK with the SDK manager
    Or, you can download the 3.0.12 manually here: https://developer.garmin.com/connect-iq/sdk/
    And then in eclipse, use "window>preferences>connect iq" to just switch the SDK root directory.  I have the 3.0.12 and 3.1.0-beta3 SDKs in the same directory so it's easy to switch.
    I do the second, and haven't had any issue with using the 3.1.0 plugin with a 3.0.x SDK, and it's quick if you just want to switch between the two SDKs
