I have an app in BETA mode on the ConnectIQ Store. I updated the latest update and I know it worked because I changed a default property, which updated as expected. I try to press the MENU button the the Forerunner 235 and I expect it to go into the options menu. But it doesn't. Hitting ENTER does not start the watch's functionality (a multi-function clock). However, hitting the LAP/ESCAPE key exits the app, after a several second delay, not expected.
Running the simulator works 100% fine. No delays, runs smooth and great. However, I do receive a memory/circular references warning. "A snapshot of active memory just before App shutdown is currently shown. These leaks... may reduce the memory available while the app is running." The following is the statistics on memory...
Memory Usage: 31.5/64.0 kB
Peak Memory: 32.5 kB
Object Usage 122/512
Peak Objects: 133
The item listed with Circular Reference! in its note has the following information:
- <Entry Point> (type) object (Created at) native function
- appView
- - app (type) object Circular Reference!
- - remind (type) boolean (value) false
- mProperties (type) null (value) null
- mPropertiesChanged (type) boolean (value) false
- appView
Any help? I'm not sure the memory is related, but thought it could help. Fixed the memory issue.
