Watchface with Seconds
Is it possible to create a watchface that contains seconds. According to the programmers guide, onUpdate is only called once every minute for watchfaces and its not possible to create a timer in a watchface.
    At this time, watchfaces can only update once per minute.
  • I think I drone on in the Programmers Guide about how watch faces only update once a minute for power reasons.
    -Alpha Monkey
    Well that is kind of a dealbreaker... The original display has no problem updating the seconds but I'm guessing it uses a different thread to do so which is less energy hungry?
  • The default watch face shows seconds and updates the steps more frequently that one minute. Please give us the ability to create a timer to show seconds or create a second hand and also provide proper guidelines to minimize power usage.
  • I'll let you in on a little secret: The default watch face does not run on the main processor, but instead runs on a much lower power micro which doesn't have enough memory to run Connect IQ. It honestly doesn't have enough memory to hold the screen buffer; I work with some mad/crazy embedded hackers here at Garmin. All that for a second hand.
    We face similar challenges to other smart watches when it comes to balancing functionality and power usage. I think all smart watches have been figuring out how to offer the customize-ability of custom watch faces without killing the battery for the use cases the devices is intended before. We're starting with a conservative approach, but it could evolve over time.
    -Alpha Monkey
  • I'll let you in on a little secret: <SNIP>-Alpha Monkey
    Thanks for the clarification!
    -Alpha Monkey
    Good stuff here! Thanks for the information.
  • I have been thinking about this quite a bit, and then it hit me that my Garmin Swim watch. What I used to wear as my every day watch before the 920 showed up. Also didn't display the seconds, until you hit a button. Then for a short while it would display the seconds then turn them off.
    That device also had a screen that would turn off it there was no movement for a certain amount of time. ( Funny that it always seemed to be about the time that it would take me to finish a portion of a task at work, then I would look down at my watch and it would be off. )
    So to get back to this thread, it got me thinking that maybe we could poll for the seconds only when say the power/ button was hit, then have a counter count them down for us, and then turn that field off again once a set time was up.
    This would;
    1. Let us save power by not refreshing every second.
    2. When the user asks for seconds we can display them.
    3.then after a set time it would again turn the seconds off.
  • ...So to get back to this thread, it got me thinking that maybe we could poll for the seconds only when say the power/ button was hit, then have a counter count them down for us, and then turn that field off again once a set time was up.
    This would;
    I also used my garmin swim as a daily watch before the 920 and think those are great ideas.
    Found that in the "Connect IQ User Experience Guide.pdf" file (SDK 0.2.4) :
    "Watch faces update at once a minute in low power mode, or once a second when in full power mode. The watch will transition out of low power mode when the user gestures to look at it. A watch face can detect if it is in low power mode or not by getting the system stats from Toybox.System."
    Isn't it true for the moment ?
