isSleepMode -?
Hi
i wrote some code checking the "isSleepMode" variable.
In the simulator everything works fine - setting "isSleepMode" changes my watchface as assumed.
But... what do i have to do / set / configure on my Fenix3 that sleepMode happens?
I set up sleeping time frame 23 - 7 o'clock. but nothing changes during that time.
Thanks
  • I don't know about the fenix3, but on the 920 and vivoactive, you go to the activity tracking widget (the step counter) and press/hold the menu key, then pick Start Sleep Mode.
    On the fenix 3 you also start sleepmode from the activity widget. You have to press start and select 'yes'.
