initialize() not called for entry point App object
The documentation indicates that the initialize() function is the object constructor, but it is never invoked for the app object. If someone decides that this isn't a bug, they should probably remove the empty initialize() method from the CommExample type in samples/Comm/source/Comm.mc since it could never be called.
D:\connectiq-win-0.1.1\samples\ObjectStore>(type source\ObjectStore.mc) && (nmake /nologo all start run)
using Toybox.Application as App;
using Toybox.System as Sys;
using Toybox.WatchUi as Ui;
class View extends Ui.View
function onUpdate(dc)
dc.setColor(Gfx.COLOR_RED, Gfx.COLOR_BLACK);
dc.clear();
class ObjectStore extends App.AppBase
var initialized;
function initialize() {
initialized = true;
function onStart() {
if (initialized == null) {
Sys.error("initialize() not called before onStart()");
function getInitialView() {
return [ new View() ];
del /s /q bin\ObjectStore.prg > :nul 2>&1
monkeyc -o bin\ObjectStore.prg -m .\manifest.xml -z resources\resources.xml source\ObjectStore.mc
connectiq
timeout /nobreak /t 2
monkeydo bin\ObjectStore.prg
Found Transport: tcp
Connecting...
Connecting to device...
Device Version 0.1.0
Device id 1 name "A garmin device"
Shell Version 0.1.0
Copying file.... 71% complete
Copying file.... 100% complete
File pushed successfully
Connection Finished
Closing shell and port
Connecting...
Shell Version 0.1.0
Success
in onStart (source\ObjectStore.mc:24)
System Error
System Error
Complete
Socket Error in packet header 0
Connection Finished
