class ViewBehaviorDelegate extends Ui.BehaviorDelegate {
function onBack() {
Ui.popView(Ui.SLIDE_UP);
return true;
I use this to handle behaviour on a View pushed by another View (i.e. a stack of 2). On the simulator, this works as it should - when I press the back button, 1 view is popped.
In the Fenix 3, 2 Views are popped. The only way I can make 1 view pop is by removing my onBack implementation. Am I doing something wrong here, or is the Fenix 3's View stack management broken? This does not happen in the Vivoactive device or simulator.
