How to draw a ring like this
Hi,
All,
somebody know how to draw a ring like this,
if use the drawPoint(x,y) to draw bit by bit ,I think this not a good way
and somebody know other way? thank you
like this watch face for fenix3
https://apps.garmin.com/zh-CN/apps/742171fd-51d5-48ac-aa0e-f09420eb8a83
Another question ,some body tell me how to upload a Attachments? I use the "Manage Attachments" below ,but can't find any "Add" button
    If I was trying to recreate that graphic, I would draw triangles (with fillPolygon) from the center, and then draw a black circle over the top in the middle.
    We will eventually be fixing issues with using pen width with draw arc, which may be a better option when it is available.
  • Unless you're going to dynamically change the shape/size of the ring, I'd either create a bitmap or pre-calcuate the points and create a shape object using the layout system.
    Yes, I want to change dynamically !
    I made something similar and used the function described here : https://forums.garmin.com/showthread.php?231881-Arc-Function&p=568317#post568317
    It draws each segment with about 30 polygons, which is a bit much for small segments.
    The function does a lot of calculations; so, if the variablity of each segment is small, e.g. only a thick or narrow segment, then they could be precalculated.
  • This is the code for my moving second indicator.
    technically 5 small arcs you want to draw.
    winkel = angle
    you can choose between 2 ways.
    1. draw a big polygon triangle
    1.1 draw a black circle in the middle with radius "width/2-5"
    2. draw a polygon with the source below, just add another loop and draw 10-20 points instead of 4
    personally i don't care about the battery used. Charging ist for free and if my high end watch has to calc 20 sin&cos ...well should be possible :-)
    hope this helps
    function drawsec(dc, rad2){
    var dateInfo = Time.Gregorian.info( Time.now(), Time.FORMAT_SHORT );
    var sec = dateInfo.sec;
    for (var k = 0; k <=59; k++){
    if ( ( k >= ( sec - 4 ) ) && ( k<=sec)){
    dc.setColor(Gfx.COLOR_WHITE, Gfx.COLOR_WHITE);
    var xx, xx2, yy, yy2,kxx,kyy,kxx2,kyy2, winkel, slim;
    winkel = 180 +k * -6;
    slim = 2;
    // 1 Polygon moving around a bigger and smaller circle
    // xx/yy----------------xx2/yy2
    // kxx/kyy---------kxx2/kyy2
    yy = 1+dc.getWidth()/2 * (1+Math.cos(Math.PI*(winkel-2)/180));
    yy2 = 1+dc.getWidth()/2 * (1+Math.cos(Math.PI*(winkel+3)/180));
    xx = 1+ dc.getWidth()/2 * (1+Math.sin(Math.PI*(winkel-2)/180));
    xx2 = 1+ dc.getWidth()/2 * (1+Math.sin(Math.PI*(winkel+3)/180));
    kyy = 1+dc.getWidth()/2 + rad2 * (Math.cos(Math.PI*(winkel-2)/180));
    kyy2 = 1+dc.getWidth()/2 + rad2 * (Math.cos(Math.PI*(winkel+3)/180));
    kxx = 1+ dc.getWidth()/2 + rad2 * (Math.sin(Math.PI*(winkel-2)/180));
    kxx2 = 1+ dc.getWidth()/2 + rad2 * (Math.sin(Math.PI*(winkel+3)/180));
    if ( k == sec ){dc.setColor(Gfx.COLOR_DK_RED, Gfx.COLOR_DK_RED); }
    if ( k == sec - 1 ){dc.setColor(Gfx.COLOR_RED, Gfx.COLOR_RED);}
    if ( k == sec - 2 ){dc.setColor(Gfx.COLOR_DK_GRAY, Gfx.COLOR_DK_GRAY);}
    if ( k == sec - 3 ){dc.setColor(Gfx.COLOR_LT_GRAY, Gfx.COLOR_LT_GRAY);}
    if ( k == sec - 4 ){dc.setColor(Gfx.COLOR_WHITE, Gfx.COLOR_WHITE);}
    if (yy > 180) {yy = yy -1; yy2 = yy2 -1;}
    // finally draw the ploygon with 4 coordinates
    dc.fillPolygon([[kxx, kyy], [xx, yy] ,[xx2,yy2],[kxx2, kyy2]]);
