Eclipse Connect IQ Syntax Hightlighting (Bracket Matching) Howto?
Hi,
i'm getting a little sick of Eclipse(Mac) - when I googled i found out that one can actually do syntax highlighting and/or bracket matching.
I'm supposed to do Ctrl-Shift-P but when I do it, it does not work.
Are there any tips or tricks on how to set up an environment for doing MonkeyC?
On windows, I find that using Notepad++ works great, I just use the JAVA as the code base/structure/syntax and I get matching braces.
Can I get a clue?
