A CIQ_LOG.txt on a Garmin CIQ widget (sun&moon) OS problem?
Ok, so I installed the Garmin CIQ 'Sun and Moon" widget on a va running 3.00 today. It worked fine the first time, but then crashed every time after that (the IQ! crash), and there was a CIQ_LOG.txt for that crash, and here it is:
in d:\projects\smartwatch\code-review\TVM\api\Ant.mb (initialize:114)
TVM ERROR:
Invalid Value
Failed invoking <symbol>
It might mean something to garmin.. But I did a bit more research. The widget created a file in the OS (a .STR file) that I saved off and deleted. It again worked once, and then crashes again. There seems to be something wrong with accessing the OS is my guess, as it is in initialize()!
