[CIQBUG] saving application properties does not appear to work as expected
The below watch-app code demonstrates a problem with serializing application properties from within a function called by App.onStop(). Start the application and you should see a 1 displayed. If you press the up/down buttons or tap/swipe the screen, you should see the value change. When you exit the application, the value should be saved, and it should be restored on application startup.
I've tested on a vivoactive and a fr920xt, and I see the same behavior on both. I had previously been able to reproduce on the simulator, but that seems to be working now. If I enable the code to save the property after every press, tap, or swipe, the value is saved, but this should not be necessary.
using Toybox.Application as App;
using Toybox.Graphics as Gfx;
using Toybox.WatchUi as Ui;
using Toybox.System as Sys;
class TestModel
hidden var value;
function initialize() {
// Sys.println("Model.initialize");
value = 1;
function serialize(app) {
// Sys.println("Model.serialize");
app.setProperty("value", value);
function deserialize(app) {
// Sys.println("Model.deserialize");
var val = app.getProperty("value");
if (val != null) {
value = val;
function incrementValue() {
// Sys.println("Model.incrementValue");
value += 1;
//serialize(App.getApp());
function decrementValue() {
// Sys.println("Model.decrementValue");
value -= 1;
function getValue() {
// Sys.println("Model.getValue");
return value;
class TestController extends Ui.InputDelegate
hidden var model;
function initialize(model) {
// Sys.println("Controller.initialize");
self.model = model;
function onKey(evt) {
// Sys.println("Controller.onKey");
var key = evt.getKey();
if (key == Ui.KEY_UP) {
model.incrementValue();
else if (key == Ui.KEY_DOWN) {
model.decrementValue();
else {
return false;
Ui.requestUpdate();
return true;
function onTap(evt) {
// Sys.println("Controller.onTap");
Ui.requestUpdate();
function onSwipe(evt) {
// Sys.println("Controller.onSwipe");
var dir = evt.getDirection();
if (dir == Ui.SWIPE_UP || dir == Ui.SWIPE_RIGHT) {
else if (dir == Ui.SWIPE_DOWN || dir == Ui.SWIPE_LEFT) {
else {
return false;
Ui.requestUpdate();
return true;
class TestView extends Ui.View
hidden var model;
// Sys.println("View.initialize");
self.model = model;
function onUpdate(dc) {
// Sys.println("View.onUpdate");
dc.setColor(Gfx.COLOR_WHITE, Gfx.COLOR_BLACK);
dc.clear();
var cx = dc.getWidth() / 2;
var cy = dc.getHeight() / 2;
dc.drawText(cx, cy, Gfx.FONT_NUMBER_HOT, model.getValue().format("%d"),
Gfx.TEXT_JUSTIFY_CENTER | Gfx.TEXT_JUSTIFY_VCENTER);
class TestApp extends App.AppBase
hidden var model;
hidden var view;
hidden var controller;
// Sys.println("App.initialize");
model = new TestModel();
view = new TestView(model);
controller = new TestController(model);
function onStart(state) {
// Sys.println("App.onStart");
model.deserialize(self);
function onStop(state) {
// Sys.println("App.onStop");
model.serialize(self);
function getInitialView() {
// Sys.println("App.getInitialView");
return [ view, controller ];
    Former Member over 9 years ago
    I doesn't seem to be necessary to me. Your code works in my simulator.
  • Okay, it looks like I was running into some other problem with the simulator. I've deleted %temp%\garmin\apps\data\* and run under the simulator again and it does indeed work as you've described. I removed \GARMIN\Apps\Data\* and then ran on my 920xt and I'm still able to reproduce the incorrect behavior.
    Travis
  • There's a bug on the devices where if App.setProperty() is called in onStop() it will not be saved automatically. You should be able to manually call App.saveProperties() in onStop() to get around this bug in the mean time. This has been corrected and will be fixed in the next release.
