Issues with buttons in the 920XT device emulator
The power button (Ui.KEY_POWER) doesn't have a mapping in device.xml for the 920XT, and the menu button (Ui.KEY_MENU) only triggers if you hold it down. The necessary changes to bin/devices.xml are pretty simple. Are these issues intentional, and if not, can I expect that my application be able handle short presses of the menu and power buttons?
  • Additionally, it seems unusual that the Enter button on the 920 results in a call to Behavior.Delegage.onNextPage(), but no key maps to BehaviorDelegate.onPreviousPage(). This essentially forces me to implement the lower-level input handling functionality provided by InputDelegate. Is this an oversight, or is this by design?
  • Also, are there plans to have the Behavior Delegate or the Input Delegate tell the difference between a short button press and a button hold?
    On my 310, I press the lap button to mark a lap and then hold the lap button to do a reset. I don't see how to mimic that functionality easily with the current tools.
    We won't have anything for launch as far as key holding. I will add "detecting a reset behavior" in the behavior delegate as a feature request.
    Nick
