ConnectIQ Datafield limitation?
Hi
Why can I only use two ConnectIQ datafields in an app on my fenix 3?
Is there a work-around on this?
Is it planned to remove this limitation in future?
Is this limitation also on xt920 and Epix?
Thanks in advance
Miguel
    Former Member over 10 years ago
    The limitation is the same on the FR920. It is not likely that these limitations will change due to system memory limitations. The devices do not currently have enough memory available to run additional data field instances.
    I am not certain if the limit is set the same on Epix. I think it may be at this time. The Epix does have more system resources than the other devices, so it is possible the limit may be raised on Epix in the future.
  • For the Epix, the limitation is 3.
