In the standard "walk", "cycling" and "run" activities, there is a way to set "auto pause", so if during a run or ride, it pauses the recording if you are waiting to cross a street or have your 4 legged friend stop to "water a bush". In a CIQ app recording a session, is there a way to set this, or does it use the setting from the standard apps?
If you can't do it in CIQ, maybe it could be added as a parameter to start(), or as a new method to set it??
