[CIQBUG] Number picker initial value not limited to bounds
The number picker documentation indicates that it is supposed to modify the initial value to be within the minimum and maximum values for each mode. In my testing on physical devices (fr920xt w/ 3.30, vivoactive w/ 2.80), the initial value is not properly limited to the accepted range. When you attempt to modify the value, the limits are enforced. On the simulator, no limit on the value is enforced at all.
As an example, if you use a number picker for NUMBER_PICKER_HEIGHT with an value of 4.0 (meters), the simulator will provide an initial value of 400.00 cm (or 157.48 in depending on the height unit setting), and will pass that value to the onNumberPicked() callback. On a physical device, the initial value displayed is 400 cm (or 13 ft 1 in). When you advance to the next number field by pressing enter or swiping, the value will suddenly change to 25.4 cm (or 8 ft 4 in).
using Toybox.Application as App;
using Toybox.Graphics as Gfx;
using Toybox.WatchUi as Ui;
class MyViewDelegate extends Ui.InputDelegate
function onKey(evt) {
var key = evt.getKey();
if (key == Ui.KEY_ESC) {
Ui.popView(Ui.SLIDE_IMMEDIATE);
else if (key == Ui.KEY_MENU) {
var picker = new Ui.NumberPicker(Ui.NUMBER_PICKER_HEIGHT, 4.0);
Ui.pushView(picker, new Ui.NumberPickerDelegate(), Ui.SLIDE_IMMEDIATE);
else {
return false;
return true;
class MyView extends Ui.View
function onUpdate(dc) {
dc.setColor(Gfx.COLOR_WHITE, Gfx.COLOR_BLACK);
dc.clear();
var cx = dc.getWidth() / 2;
var cy = dc.getHeight() / 2;
dc.drawText(cx, cy, Gfx.FONT_LARGE, "Press Menu", Gfx.TEXT_JUSTIFY_CENTER | Gfx.TEXT_JUSTIFY_VCENTER);
class MyApp extends App.AppBase
function getInitialView() {
var view = new MyView();
var delegate = new MyViewDelegate();
return [ view, delegate ];
