Watch resets after 20-30min when bluetooth is connected
I have a custom app that is using the mailbox system to send/receive JSON strings to/from a phone app. It seems to work great, but the watch (fenix3) resets after about 20 minutes. If I disable bluetooth on either end (phone or watch) the watch runs the app fine (seen it work over an hour). So what is it about the bluetooth messaging part thats killing it?
Relevant code here:
class MineApp extends App.AppBase {
//! onStart() is called on application start up
function onStart() {
System.println("onStart");
//! onStop() is called when your application is exiting
function onStop() {
System.println("onStop");
//! Return the initial view of your application here
function getInitialView() {
System.println("getInitialView");
Ui.requestUpdate();
return [ new MineView(), new MineDelegate() ];
function initialize(){
System.println("initialize");
var test = Sensor.setEnabledSensors([Sensor.SENSOR_HEARTRATE, Sensor.SENSOR_BIKECADENCE, Sensor.SENSOR_BIKESPEED, Sensor.SENSOR_BIKEPOWER, Sensor.SENSOR_TEMPERATURE, Sensor.SENSOR_FOOTPOD]);
Sensor.enableSensorEvents( method(:onSensor) );
Comm.setMailboxListener( method(:onMail) );
Comm.emptyMailbox();
timer = transmitPeriod;
Ui.requestUpdate();
//// Handle sensor Data ////
function onSensor(sensorInfo){
var senorInfo = Sensor.getInfo();
if(senorInfo.altitude != null){
timer--;
if(timer <= 0){
var devSettings = System.getDeviceSettings();
if(devSettings.phoneConnected == true){
var listener = new CommListener();
var data = fetchSensorData();
var json = jsonSensorData(data);
Comm.transmit(json, null, listener);
Ui.requestUpdate();
//// Handle Phone Communciations ////
function onMail(mailIter){
var mail;
System.println("onMail");
mail = mailIter.next();
while( mail != null ){
System.println(mail);
var vibe = new Attention.VibeProfile(100, 500);
var vibeLow = new Attention.VibeProfile(0, 200);
var vibeLong = new Attention.VibeProfile(100, 1000);
Attention.vibrate([vibe, vibeLow, vibe, vibeLow, vibeLong]);
Ui.requestUpdate();
class CommListener extends Comm.ConnectionListener{
function onComplete(){
System.println("Transmit Complete");
function onError(){
System.println("Transmit Failed");
