Why removed SoccerScoreBoard ?
Good afternoon Garmin technical support,
Why did you remove the Soccerscoreboard app?
And does App returns again ?
  • If it's a 3rd party app, it could be the developer just decided not to support it any more and removed it from the store.
    Former Member over 6 years ago
    Thank for your answer.
    Garmin is owner
    Hello Garmin Moderator,
    Why do you not give my answer?
    greetings,
  • I always have it on my watch, it's a very good application. Too bad she does not hesitate if someone knows the developer I am ready to continue the development of this application.
    Otherwise I would do it again from zero.
    I'm sad too this app is not available anymore. I still have it on my watch - and use it every time. Other apps don't fit the bill for several reasons.
    Hopefully the app gets reinstated on the IQ store! Or maybe someone feels inclined to make the app again from scratch...
    Here's all the info I have on the app, for prosperity!
    Name: SoccerScoreBoard / Soccer Score Board / Soccer Score Tracker
    Developer: Garmin (!)
    Logo: similar to this https://i.imgur.com/g5w6W1o.png
    Original URL (dead now)https://apps.garmin.com/en-US/apps/95d67fab-d771-4f52-8fe4-5561038dbe3a
    Video of operation
    https://streamable.com/1a644
    Streamable
    Mirror 1 (Google Drive)
    Mirror 2 (Gofile)
    Operation:
    Before the match the parameters of the match can be set.
    Settings (press menu): set half length (1-59 mins); set halftime length (1-59 mins); extra time (Y/N, half length, halftime length)
    To start match: press start/stop
    To pause/resume: press back
    To register goal: tap screen anywhere > tap "Home +1" or "Guest +1" (tap "Cancel" or press back to not register any goal)
    To undo registering last goal: press menu > tap "undo"
    Time management and vibrations: all vibrations are strong and have a RRRRrrrrRRRR pattern. At every time start/pause/resume/stop action the watch vibrates. When time is paused the watch will vibrate every 10secs as a reminder until time resumed.
    End of half & end of match vibration.
    The second half is started manually.
    Display
    Time of day
    1st or 2nd half
    Progress bar
    Score
    Count-down timer for the current half (big)
    Count-up timer for the total time, including time-out and halftime (big)
    Count-up timer for total time-out time (small)
    Count-down timer for halftime (small)
    Former Member over 6 years ago in reply to Alexis_Lecanu
    I have posted a reply to OP with all information that I have available for this app. Now I was able to download the app's file from my computer by connecting my watch via USB. Navigate to GARMIN/APPS to see all the install apps (they're .prg files and have unintelligible names). For me the app shows up as "6B4I0346.PRG" and is 43KB. I won't upload it here, because I suspect Garmin won't allow it...
    I have no clue about programming, so I don't know how valuable the prg file is. Regardless, I hope you feel inspired to rebuild the app with the resources available.
  • I just went looking for this app as well, as I was looking at moving phone.  But without it, or a good replacement, I'm not sure now.  I use it every week
    Former Member over 5 years ago in reply to Coleadve
    i wish someone would make a new verison of this app. it is the only reason why i refuse to buy a new garmin watch.
    Garmin would you please re-release this app?
  • I'll watch tonight if I can do the same again.
