More Accurate GPS signal? 10hz? 5hz?
I'd like to programm a Lap Timer for motorsport (kart racing). But the standard 1hz gps signal is not accurate enough. I couldn't find out what gps sensors are used in the watches like fenix 5 or newer. Perhaps the sensor is able to to get 10 (10hz) or at least 5 gps signals per second. Does anyone know?
Even if the sensor can do more and will use more battery, would it be possible to get the accurate signal with an app? Is there a way to access the hardware sensor data?
I think these are the important questions before I start. Any other app logic needed should be available.
many thanks
