I've got a very specific health issue and I need an activity to monitor my HR while sleeping. This would be for my Venue 3. Here's my requirements:
| Settings | ||||
| Data Screens | ||||
| Screen 1 | ||||
| 2 Fields | Top: | Time of day | ||
| Bottom: | Heart rate | |||
| Screen 2 | ||||
| 3 Fields | Top: | Time of day | ||
| Middle: | Heart rate | |||
| Bottom: | Countdown | |||
| Color | ||||
| Red ONLY | ||||
| Alerts | ||||
| Heart Rate | ||||
| High Alert | ||||
| Countdown | ||||
| Hours:Minutes:Seconds | ||||
| Duration | ||||
| Usage | ||
| Start activity with top right button | ||
| Screen 1 shows | ||
| Fit file created | ||
| If HR is ≥ High Alert for ≥ Duration: | ||
| Alert continues until bottom right button is pressed | ||
| Screen 2 shows | ||
| The Bottom data field (Countdown) displays a countdown timer that starts from the time the HR went over the High Alert (not the time the bottom right button was pressed). | ||
| When the Countdown reaches 0, an Alert continues until bottom right button is pressed | ||
In words:
I've got a heart issue and I need my watch to monitor my HR while sleeping. Should my HR exceed the "High Alert" setting (say 100 bpm, for example) for the "Duration" setting (say 60 seconds, for example), a High Alert warning will sound and continue sounding unit a physical button is pressed. A countdown timer will also start (say 3 hours, for example) concurrent with the time of exceeding the "High Alert" setting. If the "High Alert" setting is exceeded but the "Duration" setting isn't exceeded, it wouldn't count.
I'm currently using the Cardio activity to test this out and it kind of works. It is missing the Duration setting so I get a lot of false positives. It also doesn't have the countdown timer which is critical as it represents when I need to wake and take specific medicine!
Thanks to anyone that is willing to take this on!
Doug
