Hi I am looking for initial technology advise and potentially developers/engineers to design and manufacture a prototype etc.
We are sourcing a depth measuring device solution (GPS included and other if available) to be fitted to a mining drill which will measure the absolute hole depth (not including any seeping water) after the bore drill hole has been completed.
The solution application is for measuring drill machine hole bore holes directly after drilling the bore hole. So, when the drill bit is pulled up to top of hole and retracted slightly, we need to be able to directly measure the hole depth. So, what we would like the sequence to be is for the hole depth measuring device be fitted to the Autonomous drill machine, it will automatically extend out over the top of the drilled bore hole and measure the hole depth. The actual hole depth then will be transmitted to the Autonomous drill machine onboard ECU/ECM for next autonomous action to be processed which will be either; 1. Move drill machine to next bore hole to be drilled or 2. Redrill current bore hole. There will be some simple software dev programing to be done between the measuring device and the drill ECM/ECM which we can arrange later once we find a suitable measuring device that can accurately achieve the above.
The drill blast hole average depth from soil level top (bench level) is 12 meters to 25 meters (Average 15 meters) depending on country and ore type. The depth range is from between 6 meters to 40 meters. But is the depth measuring device is restricted by certain depths then for now lets concentrate on the average of between 12 to 25 meters.
The bore hole average diameter is between 229 mm and 270mm. The hole diameter range is between 80mm to 350mm depending on country and soli material type to be blasted etc
Now one main point in regards to the technology that is to be proposed, is that some drilled bore boles may have some water seeping into them and water levels can go up to 3m, 4m even 10 meters in some cases. So with this, the solution proposed, must to be able to measure through the water so to get actual bottom of hole drill depth so that we can confirm complete top to bottom hole depth.
This is a typical blast hole drill machine that the measuring device would be installed onto. There are many drill brands but this is quite a standard brand and model. Should be able to be retrofitted to a range of OEM drill types over time. https://youtu.be/9LCiXDWML3s
Contact via email: [email protected]
Please let me know if you have further questions. tks
