muscle heat map in glances. brightness is often changing. save weights from first rep
hello, I would like to see a muscle heat map in glances. I think my fitness will be higher if I can see my progression through the day- strength, joga, running... and- I have done a Perfect arm routine today- there are some problems- brightness is often changing (it is a problem that occurs mostly through the day), and maybe you can save weights form first rep, as we don't have to change it always from 0-100. Thank you wery much, Stevan
