tous les gps plus multibande
bonjour
je suis francais est utilise le traducteur cordialement
je suis windsurfeur est utilise des application dediés le problème c'est que j'ai investi dans une garmin forerunner 255 music ,aucune des applications ne peuvent utiliser le mode tous les gps plus multibande,apparament les developpeurs ne peuvent pas integré c'est reglages
hello
I am French, use the translator cordially
I am a windsurfer and use dedicated applications the problem is that I invested in a garmin forerunner 255 music, none of the applications can use the all gps plus multiband mode, apparently the developers cannot integrate these settings
  • Check out the latest API documentation for Position:
    https://developer.garmin.com/connect-iq/api-docs/Toybox/Position.html
    Configuration
    Configuration values for known GNSS configurations
    Since:
    API Level 3.3.6
    Name Value Since Description
    CONFIGURATION_GPS 1
    API Level 3.3.6
    GPS L1
    CONFIGURATION_GPS_GLONASS 2
    API Level 3.3.6
    GPS L1 and GLONASS
    CONFIGURATION_GPS_GALILEO 3
    API Level 3.3.6
    GPS L1 and GALILEO L1
    CONFIGURATION_GPS_BEIDOU 4
    API Level 3.3.6
    GPS L1 and BEIDOU L1
    CONFIGURATION_GPS_GLONASS_GALILEO_BEIDOU_L1 5
    API Level 3.3.6
    GPS L1, GLONASS, GALILEO L1, BEIDOU L1
    This option is supported by System 6 devices like fenix7 and edge1040
    CONFIGURATION_GPS_GLONASS_GALILEO_BEIDOU_L1_L5 6
    API Level 3.3.6
    GPS L1, GPS L5, GLONASS, GALILEO L1A, GALILEO L5, BEIDOU L1, BEIDOU L5
    Referred to as Multi-GNSS Multi-band on Edge 1040.
    CONFIGURATION_SAT_IQ 255
    API Level 3.3.6
    AutoGNSS (SatIQTm)
