Power Estimator to display Lap Average
I don't own a power meter, so I use some data fields to estimate my power. But I'm a little unsatisfied: I would like to see my average power of one lap, but no power estimator data field out there seems to be able to do this (or maybe it's simply because I only own an edge 130, I don't know). So... does anyone know a data field which can do this? Or is this undiscovered territory, which any developer might want to conquer... Any way, I'd appreciate if I could be helped out.
  • This seems to be the kind of thing that you're looking for:
    https://apps.garmin.com/en-US/apps/8dfe339a-e760-4341-b41c-2c9133b485e2
    https://sites.google.com/view/powerbikepro/configuration
    • C POWER: it is the algorithm used for Calculated POWER when a power meter is not detected.
    • A POWER: it is the 30 seconds Average C POWER algorithm. You can also chose it on the settings.
    • AVG POWER: it is the Averaged C POWER algorithm since the begining to the first "STOP" in the session.
    • LAP POWER: it is the LAP C POWER algorithm since the begining to the first "LAP" in the session.
    However:
    - It isn't available for Edge 130
    - It's not free
    - It does require a cadence and speed sensor (but not a power meter)
    You might want to go to the store page linked above and contact the developer to see if they would be interested in making a version for Edge 130. One problem is that the Edge 130 has 1/4 the available memory for datafields compared to Edge 530/etc, so I don't know if it would be feasible.
