Hi!
I would like to ask for metronome in pool swim mode to beep each time based on pool length and CSS (critical swim speed). The same functionality as Finis Tempo Trainer.
For example: my CSS (time to swim 100m) is 1:44.48 (m:ss.ms). I would like to hear beep each 26.12s (25m --> 1:44.48 / 4) or 52.24s (50m --> 1:44.48 / 2 ).
Metronome usage:
In pool swim mode I would like to go to metronome and set the following parameters:
1. pool length (25m or 50m)
2. CSS (m:ss:ms)
3. restart on inerval (ON/OFF)
4. set metronome (ON/OFF)
(Pool length, CSS and restart on interval should be displayed from last saved setting).
When I start swim activity also metronome start to beep. Metronome should beep for each 26.12s or 52.24s, depending on selected pool length.
When I select stop button, metronome should stop beeping. It would be also great, to stop metronome from Activity Settings (parameter 4).
If I select interval button and option 3 set to ON, metronome should restart.
Thanks!
