Can someone develop a widget that turns the audio promts hidden in the settings off or on?
It would of course be best if this switch could be installed in the rotating "control" menu.
The audio promts can unfortunately only be set generally spanning.
That means they apply to all apps.
Example:
You have to go in to the settings every time before hiking and switch off the audio promts for the ∅pace and after the hiking you have in to go again in to the settings and switch on the audio promts, because normaly you use this audio promts for the daily running trainings.
This is annoying and could be simplified with a little widget.
