Datafield "Ahead - behind time" of Virtual Partner
Hi,
I use 920xt and 630 watches.
I am a heavy user of "Virtual Partner".
I use it :
- with the Virtual Partner speed
- with virtual racer
- when I am running "workouts" and using "speed target intensity" on each step.
But to have access on the important part of VP (the "ahead - behind time"), we have to go to the "Virtual Partner screen".
This VP screen is interesting but it has data that are not always interesting and are sometimes useless.
So, I would really like to be able to display on the other screens this value, the "ahead - behind time".
So, I woud like that someone develop an IQ app to create this "ahead - behind time".
I kwow that this is now not possible because "ahead - behind time" is not a standard accessible Garmin data in IQ app's.
So, I ask Mr GARMIN, to add this data on the list of his standards datafields, usable in IQ app's.
Can the "Connect IQ team" transmit this requirement to Mr GARMIN ?
THANK YOU.
    As you already mentioned, time ahead/behind from the build in virtual partner is not accessible from Connect IQ.
    Maybe my Virtual Pacer data field provides you the functionality you need. If you set it as a half screen data field (or middle field on 3 field layout on fr630), it displays required pace and time ahead/behind. It does however require you to set the target distance and time separately with app settings in Garmin Express or Garmin Connect Mobile.
  • Datafield "Ahead - Behind"
    Happy New Year to everybody.
    Thank you TeunMo.
    Have you an idea why this field is not in the list of those accessible from Connect IQ ?
    Thank you TeunMo.
    Garmin, can you tell why this time ahead/behind is still not accessible, and we have to use Garmin Connect Mobile to set the target pace? Would it not be very easy to add it? I reckon for many, to have time ahead/behind as a single editable field, would be one of the main features. Next step would be then if user could add the target pace during the run by holding up key over 2 seconds, and could then reduce or increase the target.
