¿PacePro puede calcular la ruta con dos vueltas en la misma dirección?
Cuando añades un trayecto puedes indicarle los siguientes modos:
  1. Bucle al inicio
  2. Ida y vuelta
  3. Invertir dirección
 ¿Cómo podemos incluir el número de vueltas que se hace al mismo trayecto en la misma dirección? Si no se puede, sería genial ya que en PacePro podría analizar un trayecto según las veces que lo realizas, de modo que influirá en la estrategia según las veces que lo haces.
Muchas gracias de antemano.
Saludos
    0 Former Member over 5 years ago
    When you add a route you can indicate the following modes:
    Loop at start
    Round trip
    Reverse address
    How can we include the number of laps that are made to the same route in the same direction?
    If you can't, it would be great since in PacePro you could analyze a journey according to the times you do it, so it influences the strategy according to the times you do it.
    Thank you very much in advance.
    regards
  • Hola! Tuviste la respuesta a este problema? yo también quiero saber Disappointed
  • How can we include the number of laps that are made to the same route in the same direction?
    If you mean running the same Course several times, then just create it as a single circuit (if needed you can restart it each time you enter the same circuit), and set up a position-based auto-lap, if your watch supports it (most of the current models do). The setting is in the Run activity Menu » Run Settings » Auto Lap » Mode » Auto Position. The watch then detects when you enter the same spot where you pressed the Lap button manually the first time..
    You can see it documented for example in the F7 manual here:  fēnix 7 Standard/Solar/Pro Series Owner's Manual - Activities and App Settings (garmin.com)
    Auto Position  option marks laps at a location where you previously pressed LAP .   When you complete a lap, a customizable lap alert message appears. This feature is helpful for comparing your performance over different parts of an activity.
    If you do not have a watch supporting the feature, then either get one, or just mark all the laps manually yourself
