Watchface request...
Request for this simple (I think) watchface...my graphic skills aren't the best, obviously the dots should be spaced evenly, etc.
Red Dots = Move Bar
Blue Dots = Percentage to Step Goal, each dot represents 5%
Green Dots = Batter, each dot represents 20% battery
Simple time with no AM/PM or seconds.
Thoughts? Is this doable? Looking for some simple and not too cluttered...am open for suggestions as well...thanks.
  • Request for this simple (I think) watchface...my graphic skills aren't the best, obviously the dots should be spaced evenly, etc.
    Red Dots = Move Bar
    Yes, very doable. But as I don't have a F3 to test on, it's not for me to do (and I'd probably add am/pm, seconds when not in low power, and a indicator of a BT connection somewhere, as all are easy to do). I do like the design though!
    I might also change what some of the dots are for. For example, the move bar only needs 5 dots. 1st dot is one hour, and next 4 are for each 15 minutes each.
    Maybe use the 5 battery dots for the move bar, and use the big number of dots for move as the battery level (as battery can go 0-100)
    I'd be fine with changing the dots around somewhat (didn't know those details behind them), but I don't want the other stuff (BT, AM/PM, seconds etc.) on there even in high power mode...I've found I really have no need for them. Don't care about seconds, I know when it's AM/PM and I pretty much know when the BT is connected.
  • I'd be fine with changing the dots around somewhat (didn't know those details behind them), but I don't want the other stuff (BT, AM/PM, seconds etc.) on there even in high power mode...I've found I really have no need for them. Don't care about seconds, I know when it's AM/PM and I pretty much know when the BT is connected.
    You got to understand that unless you pay someone to build exactly what you want (or you build it yourself), the person building it will probably add stuff to make it match what other users may want. (the 3rd party folks usually don't want to do a "one of" for anything) Some of the things you don't want could be the first things requested when it hits the app store.
    I understand what you are saying, but that's why this was a request. To see if someone would build this as I requested it...if not then those are the breaks. I don't have any clue how to do it myself or I wouldn't have put out a request.
    As for the "stuff that other users want," there are already numerous other watch faces that don't have that stuff that are popular. My current favorite doesn't, just doesn't have the movement stuff.
