Die FW 3.30 für Oregon 6x0 ist da.
Changes from version 3.10 to version 3.30:
Improved GPS performance
Improved battery save mode: The first press of the user key or the power key to turn the screen on will no longer execute that key's customized function
Improved pairing behavior with cadence sensors
Fixed Latvian keyboard
Fixed issue with geocache ratings when using the 'Next Stage' feature for multicaches
Fixed display of certain map names when viewing the list of maps loaded on the device
Fixed inconsistent exponent formats in the Calculator application
Fixed possible shutdown when viewing the Elevation Plot in landscape orientation
Fixed possible shutdown when selecting a route in the Route Planner application
Fixed possible shutdown when exiting the Photo Viewer application
Fixed possible shutdown when using the Geocaching dashboard in the Compass application
Fixed possible shutdown when using certain dashboards on the Main Menu
Fixed possible shutdown when sorting tracks alphabetically in the Track Manager application
Fixed possible shutdown when selecting a track from the Calendar application
Fixed possible issue with overwriting waypoints received by the Share Wirelessly application
Über BaseCamp bzw. Webupdater funktioniert es bei mir nicht. Habe die Datei direkt geladen.
Zum direkten Download:
http://www.garmin.com/software/Oregon6x0_WebUpdater__330.gcd
- Datei umbenennen in GUPDATE.GCD
- auf das Oregon in den Ordner garmin kopieren
- Gerät mit vollen Batterien starten
