Edit Multisport activities
Hi,
I tried the search function but could not find anything to resolve my problem..
I have done a triathlon on the weekend and uploaded it to Garmin Connect. I really like that it now shows u as a single event and not as 5 individual activities as before (swim, bike, run and 2 transitions).
My problem is however that I cannot edit the workout. Like so many times I forgot to press lap after the triathlon and now my total time is way too long. I tried to use the edit function and just change the time (how I can do it with normal activities) but my changes are not being saved.
I am not sure if that's a bug, was done by intention or I simply make a mistake but does anyone have a solution on this?
Any help is really welcome!
Thanks
    0 Former Member over 10 years ago
    Hello Alan,
    Certainly. Attach your file to another post here and someone will make you a multisport file.
    Hi Datezz,
    Thank you for the reply. Here is the fit file for the one who can adjust it.
    Many thanks.
    Greetings,
    Alan
    Hello Alan,
    There is no device listed in your file. If you want it added to your fixed track just send a post back with a description of it.
    All the rest of the data looks okay.
    So....here ya go. A MultiSport created with the Fit File Rep[air Tool.
    https://www.dropbox.com/s/8t0g3lsczqla7cy/MultiSport-fixed.fit?dl=0
    Hi Datezz,
    Just brilliant!! Thank you very much. Hope it did not take you too much time. Maybe in the future I can learn how you did it :).
    Once again many thanks for the fix.
    Greetings,
    Alan
    Ps device is a 310xt. Though i do not expect you to add it in, was just to answer your question about which device.
    First Xterra Triathlon File - is not showing the different sports
    I did my first Xterra Tri a few weeks back and the file shows all disciplines as one sport. Can this be fixed? I have attached the fit file....
    thanks for any help!
    Multisport Wrongly Recorded Due Missed Pressing of Transition Button for T1 on 920xt
    Hi,
    I did my 1st OD Triathlon & missed pressing the transition button on my 920xt. It ended up T1 took 1 hour and 31min and cycle took 3 hours and 13mins. Anybody knows how this can be fixed?
    Here ya go. Fixed with the Fit File Repair Tool.
  • Hello,
    I did Ironman UK 70.3 yesterday but my Fenix 3 got knocked in the swim leg, and went into Transition 1.
    Is there a way I can edit the T1 "marker" to correct this? I checked the multi-time when I came out the water so I know my swim split needs to be 36:20, and I also know that I started the bike leg at the correct time.
    Can anyone help with this please?
    Multisport activity fail Garmin Fenix2 - please fix
    Hi there,
    yesterday I did my first extreme triathlon on 70.3 distances. I used Multisport activity tool. However, when i uploaded into garmin connect it turned the last activity as a swim, although in the settings I had following: Swim/Bike/Run and Transitions:On.
    This was really an important race for me and wish I had valuable data from.
    Hereby I attach the fit file. Can you please fix it for me and change the last swim activity into run?
    Can you also identify what migh be the possible cause of this error?
    My gear is Fenix 2. Sometime it is difficult to rely on this watch because they sometimes act as if memory is full, although memory is like 10% full and reboot with no reason. This is quite annoying for 450 EUR watch. However, I never expected that multisport activity would be damaged as well as these watch are marked as triathlon watch.
    Thanks a lot
    Vladimir
    Hello Vladimir,
    Your Fenix really made a mess of your file. After the swim all fitness data is gone except calories. No elevations, HR, cadence, etc.
    All laps show zero distance?? There are coords and time and calories for 112km and strokes (cadence) for the swim only.
    I used the Tool to rebuild the 5 sessions and add elevations from the database.
    I did not remake any laps.
    So....here ya go. Rebuilt a MultiSport with the Fit File Repair Tool.
    https://www.dropbox.com/s/tjx8s4lqr1p3uuk/2015-07-18-15-53-03-MultiSport-fixed.fit?dl=0
