Edit Multisport activities
Hi,
I tried the search function but could not find anything to resolve my problem..
I have done a triathlon on the weekend and uploaded it to Garmin Connect. I really like that it now shows u as a single event and not as 5 individual activities as before (swim, bike, run and 2 transitions).
My problem is however that I cannot edit the workout. Like so many times I forgot to press lap after the triathlon and now my total time is way too long. I tried to use the edit function and just change the time (how I can do it with normal activities) but my changes are not being saved.
I am not sure if that's a bug, was done by intention or I simply make a mistake but does anyone have a solution on this?
Any help is really welcome!
Thanks
    0 Former Member over 10 years ago
    Hello Matt,
    Your file did not load into the Tool as a MultiSport. It does have 6 laps of various lengths that I merged together making 1 complete 4.6 mile lap.
    Your 13 minute stop in the park is there and then you went on home. All the track and data look okay.
    So....here ya go. Merged and fixed with the Fit File Repair Tool.
  • Hello Matt,
    Don,
    It looks like it worked great! Can't thank you enough. Do you know if there is a Mac version of the FFRT?
    Also, I just wanted to show you how that activity uploaded into Garmin Connect as a Multi-Sport activity. It's strange that it didn't show up in the FFRT program as one.
    https://www.dropbox.com/s/evygscw2ny2arzs/Screen%20Shot%202015-05-08%20at%2012.28.33%20AM.png?dl=0
    https://www.dropbox.com/s/g4tp7t7mffqsrf4/Screen%20Shot%202015-05-08%20at%2012.34.38%20AM.png?dl=0
    Thanks again,
    Matt
    Hello Matt,
    That is very strange. Apparently Connect thought the 13 minutes in the Park was a transition or something??
    Anyway, you are welcome. It's always nice when the data is there and the Tool can fix it.
    I'm having the same problem.
    ">ผลบอล">ผลบอล ">ผลบอลสด">ผลบอลสด ">วิเคราะห์บอล">วิเคราะห์บอล ">livescore">livescore ">ไฮไลท์บอล">ไฮไลท์บอล
    I have two workouts that somehow got merged into one multi-sport activity. I'm guessing I forgot to hit the reset button, they are on two different days so I'm not sure why they are linked...anyway is there a way to unlink them? One is a bike ride and the other is indoor cardio. Thanks
    Hello Ruth,
    Certainly...attach a copy of your file to another post here.
    I have had a problem with the multisport mode that is just a bit different than those on here already. What I have is a workout that wasn't supposed to be multisport and now I can't undo it. Basically I started my watch while on a bike ride but I was still in run mode. I noticed after only 11 seconds and switched over to bike and finished the workout. Now it is listing the whole workout as a multisport activity, I managed to change the activity type of the "run" 11 seconds to Cycling but it still lists it as a multisport with two legs. What I would like to do is simply split the activity out of multi sport or delete one of the activities. Any help would be great!
    Hello Bmolloy,
    Piece of cake :o
    Attach a copy of your original file here and someone will take a crack at it.
    First attempt at multisport mode - fail
    Hello Bmolloy,
    Piece of cake :o
    I tried to record my race in multisport and it doesn't seemed to have save properly - can it be corrected to show the different events and transitions?
    Thanks!
    Robyn
    Hi Everyone,
    Recently I did a 1/8 triathlon and I wanted to do it in Multi sport mode. Had everything set at the start, start sign went and I pressed the Start button :S instead of the Enter button. In otherwords I went off doing my contest in Running mode, but I did press the lap button by each change of transition and start of the next discipline.
    My question is can I or with help of some tweak my fit file from an running to a multi sport (Swim-T1-Bike-T2-Run)?
    Hopefully you can help me.
    Kind regards,
    Alan
