Edit Multisport activities
Hi,
I tried the search function but could not find anything to resolve my problem..
I have done a triathlon on the weekend and uploaded it to Garmin Connect. I really like that it now shows u as a single event and not as 5 individual activities as before (swim, bike, run and 2 transitions).
My problem is however that I cannot edit the workout. Like so many times I forgot to press lap after the triathlon and now my total time is way too long. I tried to use the edit function and just change the time (how I can do it with normal activities) but my changes are not being saved.
I am not sure if that's a bug, was done by intention or I simply make a mistake but does anyone have a solution on this?
Any help is really welcome!
Thanks
  • nyc tri
    Hi! I just raced in the NYC tri this past weekend. I messed up my Triathalon recording. I had messed up T1 and my bike leg.
    Could someone help me modify my FLT file?
    Here are my results:
    SWIM - distance - 15km (21:56min), Pace: 1:19100 yds. cTim 00:21:55:30
    T1 - 8:22 min c tim 0:30:17:00
    Bike - 40KM *(1:18:59 min) Pace: 18.9 mph, cTim 1:49:15:85
    T2: 2:24 min, ctim 1:51:39:05
    Run 10KM (52:50), Pace: 8:26/mile , cTim 2:43:58:60
    Finish: 02:43:59
    Thanks!!!
  • nyc tri flt file...
    sorry admins - I hope this is not a re-post!
    Finish: 02:43:59
    Thanks!!!
    0 Former Member over 10 years ago
    225
    Hello Vladimir,
    Your Fenix really made a mess of your file. After the swim all fitness data is gone except calories. No elevations, HR, cadence, etc.
    All laps show zero distance?? There are coords and time and calories for 112km and strokes (cadence) for the swim only.
    I used the Tool to rebuild the 5 sessions and add elevations from the database.
    I did not remake any laps.
    So....here ya go. Rebuilt a MultiSport with the Fit File Repair Tool.
    https://www.dropbox.com/s/tjx8s4lqr1p3uuk/2015-07-18-15-53-03-MultiSport-fixed.fit?dl=0
    Thank you very much for saving my data!
    However, today I went for a short bike and it shows a line on a map between a place I were yesterday and place I am at currently. It appears as if the activity happened yesterday. Can you also please take a look at this file? Is there any remedy for Fenix 2 issues?
    Hello Vladimir,
    For some reason your Fenix kept 1 trackpoint from 7-18-2015.
    That is why there is a long straight line to the start of your ride in 7-20-2015.
    I removed that 1 point and the rest of the file is fine.
    I do not have a Fenix but on a map the data has huge gaps between trackpoints. I think you have it set on "UltraTrack".
    I would turn off UltraTrack and not use "3D Speed and Distance".
    Make sure you delete all activities from the watch after uploading to your computer.
    You might consider a "Reset to Factory Settings". Owners manual page 14.
    Here is your ride fixed with the Fit File Repair Tool.
    Hello!
    During my last triathlon I accidentaly pressed the lap button twice when exiting T1 (it was my first time using 920xt - on my previous watch 310xt you needed to press it much harder, which was probably the reason for the mistake). As a result my bike split is 0 seconds and T2 contains the whole bike split as well as T2.
    Could anyone kindly help fixing the FIT file? I need the 3rd section end mark to be pushed out by 1h15m30s
    Below some more details:
    Swim: 0:32:08 -> correct
    T1: 0:07:05 -> correct
    Bike: is 0:00:00 -> should be 1:15:30
    T2: is 1:21:18 -> should be 0:05:48
    Run: 0:59:45 -> correct
    I'm attaching the FIT file.
    Many thanks in advance for your help!
    Michal
    Hello Michal,
    Here ya go. Fixed with the Fit File Repair Tool.
  • Dear,
    I would like to export a multisport activity form Garmin connect, but I would like to export as 5 individual files. One per swimming, one fot T1, one for bike,...
    I was able to export as a unique tcx file, but I want 5 files.
    Thks
    Hello Wind_Dre,
    Open your file in Connect Modern.
    Click on the Swim so that it opens and shows on the map.
    Then upper right corner click the little gear and chose "Export Original" (FIT file) or "Export TCX".
    You will get a file that covers just the Swim.
    Do the same for all the rest. :)
  • Hello Wind_Dre,
    This is exactly what I did, but the .fit file downloaded contains the 3 sports.
  • Fit File Repair Tool could be useful for me, to try to split in 5 different files and then import each one to Strava. But I think that Fit File Repair Tool is not compatible with Mac. Isn't it ?
