Edit Multisport activities
Hi,
I tried the search function but could not find anything to resolve my problem..
I have done a triathlon on the weekend and uploaded it to Garmin Connect. I really like that it now shows u as a single event and not as 5 individual activities as before (swim, bike, run and 2 transitions).
My problem is however that I cannot edit the workout. Like so many times I forgot to press lap after the triathlon and now my total time is way too long. I tried to use the edit function and just change the time (how I can do it with normal activities) but my changes are not being saved.
I am not sure if that's a bug, was done by intention or I simply make a mistake but does anyone have a solution on this?
Any help is really welcome!
Thanks
    combine gpx to fit
    Hi,
    any chance one could create a multisport session out of the 5 .gpx files?
    Thanx in advance for helping me out :)
    Regards
    Eldrik
    Hello Eldrik,
    That ZIP file is corrupt. Try putting all the FIT files in a folder then ZIP that folder and attach it again.
    Hi DATEZZ,
    reziped it.
    https://www.dropbox.com/s/4gdrfqshyxc6cps/Triathlon_new.zip?dl=0
    The zip contains 5 gpx files that I need to combined to one multisport activity fit.
    Thanx in advance.
    Regards,
    eldrik
  • Merge two multi sport files for me
    Any chance you can merge these two multi-sport *.fit files for me? I pressed the lap button too many times and had to start the multi-sport mode over on my 70.3 yesterday. The first *fit file (69B73429):keep the swim and T1 (5:13 in length) and the second (69B82148) *.fit file keep the bike, T2 and run. All the other junk that is only a couple seconds long can be deleted and just one fit file created. I know the lengths are not a perfect 70.3, but I'm fine with that. I'd like to just have all the data in one file instead of two.
    Here is the link:
    https://dl.dropboxusercontent.com/u/53969963/69B73429.FIT
    https://dl.dropboxusercontent.com/u/53969963/69B82148.FIT
    Hi DATEZZ,
    reziped it.
    Thanx in advance.
    Regards,
    eldrik
    Hello Eldrik,
    You sent GPX files which have no device info, HR, Cadence, Calories, etc.
    So the manufactured Triathalon has none of that data, just distance and speed.
  • Help!
    I've been trying to fix my triathlon file all morning and can't get it to work with any free tools, Completed a short race yesterday and accidentally forgot to end the race at the finish line, walking around for an about 5 minutes before realising. DATEZZ can you please help?
    Hello Stewart,
    I made 2 fixed files.
    Both files have the 5m20s removed from the run.
    The rest of the plain "fixed" file is unchanged BUT the cycling session is a mess. Speeds jump 20/30km/h in 1 second. In one spot it jumped from 57 to 101km/h and it recorded the bike distance as 42kms.
    The other file "GPS fixed" has the distances repaired using the GPS coordinates and GPS speeds.
    Both files will open in Connect at the same time and you can compare them and keep the one you want.
    https://www.dropbox.com/s/653w8zqnh66aca9/rhys.stewart.zip?dl=0
  • Hello Stewart,
    Thankyou very much Don, the magnet on my wheel got knocked and stuffed up all my speed during the ride unfortunately. It made for interesting viewing as I apparently maintained over 70km/h off a downhill one lap and the next I couldn't even hit 20km/h spinning out my top gear.
    Thanks again.
    How to split multisport activity to individual FIT files?
    Hi,
    could you give me a hint how to split multisport activity into individual files with single sport activity?
    Started accidentaly my bike ride as running activity, when I realized that, I just changed activity to bike and the result is multisport activity.
    For further processing of activity FIT file I need a single activity file.
    How can I create such file?
    GC features are very poor in this sense - I tried to export FIT files from single activity view, but I keep getting multisport FIT file only.
    Could you give me a hint? File is attached. Thanks.
    Multisport
    I ran a triathlon yesterday, and I too, forgot my watch. I can not manually add my triathlon from the stats provided by the race. This is very aggravating. Can you please tell me how to add a multisport event (triathlon) that allows me to put my swim time TI time bike time T2 time and run time. You would think Garmin would make this easy for someone who has invested $500 on a tri watc.
