If you've enabled LiveTrack with "Extend Session Visibility," and it's not past 24 hours ago, you might be able to recover the GPS track using a LiveTrack converter, such as LiveTrack…
What was the distance supposed to be? I see about 2.9 miles or 4.7 km.
Some fit files can be fixed by FIT File Tools, using the section remover without any adjustments. The result can then be uploaded to Garmin Connect Web using the Import Data page. I tested your file, so this…
solved
Hi,
I was able to recover an activity I inadvertently discarded using DMDE. But I'm unable to upload it Strava and am unable to fix the .fit file with FIT File Tools. Can you please take a look at my file?
https://drive.google.com/file/d/16ZUVK_XURM0vTVKsvLhciLSkf-_8Lix1/view?usp=sharing
solved
Hi OnlyTwo, any chance that using a different file recovery program would be able to recover a .fit with data in it?
I deleted my running activity immediately after ending the session. Unfortunately my smartphone was switched off at that moment.
It seems like several recovery software even don't recognise my Venu2 watch.
While manually browsing through the device activity folder (Windows), I can only see previous activities.
I guess I don't have any chances at all to recover todays session?
solved
Hello Former Member, thank you for your reply.
Deleting my music first won't help either?
Hello there, I accidently deleted an activity.
COuld you try to helo me to fix the FIT file?
Thanks.https://drive.google.com/file/d/1cyVDrh_NUyzK3MGJdOa-H0CfiBfJUNmv/view?usp=sharing
This will work - 2022-10-08-07-01-27-fixed.fit
Hello,
I did a missclick in my ride today. I clicked on "Deleted" and I don't know if it is possible to recovery a .fit files. Please find what I found with Recuva.
https://drive.google.com/drive/folders/1jhSLN43B3SPyfG_ThTz-iRksk6TVZ8G3?usp=sharing
Thank you for your help !
