If you've enabled LiveTrack with "Extend Session Visibility," and it's not past 24 hours ago, you might be able to recover the GPS track using a LiveTrack converter, such as LiveTrack…
What was the distance supposed to be? I see about 2.9 miles or 4.7 km.
Some fit files can be fixed by FIT File Tools, using the section remover without any adjustments. The result can then be uploaded to Garmin Connect Web using the Import Data page. I tested your file, so this…
thanx man,really appreciate it!!
Hi ! Unfortunately I had the same problem (deleted a file on my watch). I found one file with Recuva. But i cannot upload it manually (it says that the file is note accepted by the system).
https://drive.google.com/file/d/13ByBxYE1jKDpAcuHT9hSmI6PcNhS-zsK/view?usp=sharing
Could someone help me with this ? (I tried the FIT file Tools but it didn't work, maybe i did it wrong...).
Thanks a lot !
If you delete it off the device it is gone forever. There is no data file backup on your device. As a programmer, I'm amazed they didn't add in a backup feature for deleted files. I always do that and set it up to fall off after a certain number of days.
I'm selling all my Garmin devices and buying a Wahoo for my bike. Problem solved.
Hi
I would like to ask for your help
Lost my ride on my garmin about 57km, i dont know if i discarded it or it didnt save but i was only able to recover the first 3 minutes. https://drive.google.com/file/d/1TEZKt7vy1_YVs_CBANxDfCCZKK9oSN60/view?usp=sharing Is there more in it? Would mean a lot for me,
Tx in advanc
Thank you for the effort :)
Hi
I’ve managed to recover a file using recuva but manually uploading the file isn’t working.
Are you able to take a look for me?
https://drive.google.com/file/d/1mZVy431zVhLeMMlK4fNiCE9-CU8X7XeX/view?usp=drivesdk
thanks in advance!
Apologies! Now made public I think! Thank you!
