Hello together,
actually is a problem to connect the app to Yazio. This problem is since the last damage.
How long do you think is the problem?
Greats from Germany
Sven
Hello together,
Greats from Germany
Sven
I'm not familiar with this app, but if it's like the other connected apps, you might have to re-establish the connection between Garmin Connect and Yazio.
This is typically done by going to Yazio, disconnecting Garmin Connect. Go to Garmin Connect, disconnect Yazio. Go back to Yazio and connect again to Garmin Connect.
Hi, I have the same problem - but reconncting doesn't work because it says 'reconnect' but it doesn't show me the garmin website for consent and therefore the yazio app doesn't reappear in my garmin account information. So it's worse now. Kind of. No connection no snchro no nothing.
I was going to step through this to see if I could replicate your issue. However, it requires me to "unlock all" and pay for the service. I assume you are a paying customer of Yazio? Other than that, I checked the Yazio support site and noted these items.
Which apps & devices can connect with YAZIO?
On that page it states "It is not possible to connect YAZIO to more than one app at a time." Not sure if that's your issue or not.
Which data are being synced between YAZIO and Garmin?
The following data are sent from Garmin to YAZIO:
The following data are sent from YAZIO to Garmin:
Also, this was mentioned on the German forum. Translated here...
Suggest logging out of Garmin Connect completely, as it is probably pulling your saved credentials using OAuth or saved passwords in the browser. Or try a different browser.
From Garmin's support site - Data from My Garmin Connect Account Is No Longer Syncing over to My Third-Party App
I have the same issue so I went to the Garmin website and found this:
So Garmin is not partnered with Yazio anymore.
