Our engineering team is actively working on this issue. It has been given a high priority and we hope to have a permanent solution available soon.
A workaround that worked for me was change one of the planned workouts a little (added 1sec to a training) and then is wants to upload all planned workouts again. This solved the problem for me at least…
The solution is much simpler, and was mentioned many times in this thread, as well as in many other ones about similar topics. Simply add any dummy workout (it can be completely unrelated to the coach…
Update: As suggested by one of the post, I added one second to tomorrow’s schedule run on my Garmin app and synced again. Now the workouts for the rest of this week show up in the training calendar my…
how is this still not solved? i can't believe i'm holding a $700 watch in my hand and can't get my training plan on it! I've never been so frustrated!! Garmin, please take care of this
Has this been fixed? I am having the same problem with my Fenix 3.
How your ´engineering team is actively working on this issue. It has been given a high priority’ and I still have the same problem on my Fenix 6x sapphire. Explain please, how I’m having the same issue after one whole year of your response that you guys are ‘Working on it’
Hi, i have this issue on my 245 music. I did a benchmark run for the coach and then when i tried to use again for the next session just asked me to download training plan from connect. I did this and resynced many times but still the same message.
1 second solution is not working for everybody. Stop pushing that.
Why not? In most cases it helps quite fine. If it does not work for you, it does not mean other people won't be glad to fix it in that way.
It is not possible to edit the garmin coach exercises, so if people get this issue when on a gamin coach plan, they can't use that solution. I am on week 12 of a half marathon plan, and all of a sudden the garmin coach workouts are not syncing. I have tried every answer in this thread numerous times, nothing works.
Sorry to disappoint you, but I will continue offering the solution, since I see that it usually helps (as you can also easily see by reading this thread). I am sorry if it does not work for you, but it is no reason for hiding the simple hack from others.
