Vivosmart hr+ gps issue
Hi all,
My band can no longer lock onto gps signal. I tried syncing with garmin connect and express but it still didn't work. The gps signal will be stuck at 1 bar.
Any suggestions?
Thanks,
HH
    0 Former Member in reply to Former Member
    How do you fix it? By updating in express? TIA
    0 Former Member in reply to 5844526
    The same thing happens to me too.
    I also did a factory reset and removed it from my account.
    The problem persists.
    I'm having exactly th same problem IV tried everything
    I spoke to someone from the Garmin support team, and this issue was fixed for me in minutes. I was instructed to connect my watch to my laptop and then delete the current remotesw file from it, and empty my trash after also. I then had to reconnect my watch to laptop and re-sync it using Garmin express, to get a new remotesw folder with updated satellite connectivity. I then started an outdoor activity, and left it outside on the bit where it would usually be stuck on waiting for GPS signal for a very long time.
    The person I spoke to said that it could take up to 40 mins to reconnect to the satellites and get a GPS signal, however mine took less than 5 mins after doing the previous steps. I hope this helps!
    Thank you.. I'll try this solution.. Hope works on my end
    Thanks for adding to this thread.  It's the one that worked for me.  I tried deleting the file and the re-sync and leaving the watch outside for a bit... and it's working.  Thanks again!
    0 Former Member in reply to 4365586
    This worked for me!
    This solution worked for me, too!  Thank you.  Just downloaded Garmin Express and connected to my device.  That was it.  Thank you!
    Hi
    Having the same issue with my vivosmart HR+
    Connected it to Garmin express and did sync. After sync I could see the 'epo. Bin' file.
    Then I checked my device, the issue was still there.
    Connected my device back to PC, now couldn't see the 'epo' file !!!
    Somehow it got deleted !!!
    Please suggest if there is any other solution
    Thank you
  • This solution worked for me today!  Thank you very much for posting this fix online!  I would like to add something for other users who may be having this GPS issue. The first time I tried the solution mentioned above it did not work, but then I tried it again a little differently the second time. So the second time around I first deleted the epo.bin file that was inside the remotesw folder, and then I deleted the remotesw folder.  After that I ejected/disconnected my vivosmart hr+ watch from the computer *without* re-syncing the device to Garmin Express.  I waited a few moments.  Then I connected my watch to the computer again and Garmin Express synced the device (thus replacing the remotesw and the epo.bin files with new ones).  I then ejected/disconnected my device from the computer and went outside.  I started an activity, selected GPS outdoor, and it got a signal within a couple of minutes!
