The temperature is still coming up in Fahrenheit rather than Celsius on the metric setting. Is there any way to set the temperature to Celsius? Or is this a Garmin programming fault?
Note: the setting is on metric.
Hello! Are you making this change through the device or on the app?
Hi! I made the changes throufh the app. I've tried on the device, however couldn't find the settings for weather.
Hello! Can you adjust your settings in the Garmin Connect Mobile app to miles, sync the device, and then switch back to kilometers and resync.
Please let me know if this works.
Worked perfectly for me.... thank you so much it was driving me insane!
No problem! Feel free to tag me anytime if you have questions!
For new users this is insanely confusing and frustrating! There are TWO sets of settings in the app. The one that you would THINK changes to metric is ONLY for the app. In the app, you must select your device first and THEN settings if tou want to change to Celsius on your device. Literally took me more than half an hour to discover!!! Poor UI design if you ask me.
Same here. I have the new Vivosmart 5 that i received yesterday. Tried yesterday and today and finally found this thread. I've been disappointed with the watch until now. This needs to be fixed , new watch users should not experience this.
The problem is there's not 2 but three Settings, and the 3rd one is buried.
1. On the watch itself you can swipe down to setting and set it to Celcius, but it does not change.
2. The app UI allows you to set it to Celcius but again no change
3. In the app, if you select your device, then you'll see your device settings and here these changes will sync and be permanent.
Poor design.
