Hello
after uploading the Sensor Hub 6.64 Fix, my vivoactive 3 watch stopped showing temperature and atmospheric pressure. I reset it in various ways and it didn't fix the problem. Still doesn't show temperature and pressure.
Greetings
Radek
Hello
Greetings
Radek
Thank you for your help.
In the service mode, the sensors work normally (show values), but in the application / Crystal dial the temperature and pressure are not shown, before the Sensor Hub 6.64 Fix was uploaded, it was working properly. I have no idea what's wrong. Anyone have a similar problem?
I also made the Sensor Hub Fix 6.64 because GPS-Version showed 0.00
Now the Barometer Test in the hidden menu is invalid and the system doesn't count regular floors.
On the other hand while running in flat area it shows 141 floors for a disance of 8km.
It seems that the fix destroyed the altimeter sensor.
Hardreset doesn't solve this problem - it is annoying because before performing the fix the altimeter sensor worked flawless and accurate.
Garmin requests you to contact support in that case.
You can also try to do a master reset, although it did not fix all issues for this user.
