Sensor Hub 6.64 Fix Information
Good morning,
I tried to.update the software manually as  suggested, but the GPS software is still version 0.00. Since the automatic update I'm experiencing a severe battery drain.
How can I solve it?
Thank you and have a good day
  • If you have already tried updating the watch with Garmin Express (How Do I Install Garmin Express?) and that was unsuccessful, I encourage you to reach out to your local Garmin Support team directly.
    To do this, type "support.garmin.com" in your address bar and use the Garmin Support Center to research your issue.  Once you get far enough in the search, you will see (at the bottom of the page) some contact options, which may include Call, Chat, and Email.
