How do I reset the Vivosport to remove the 100% Battery screen? Even syncing doesn’t work. Thanks!
Don't laugh... I had the same issue and tried everything to fix it short of hitting it with a hammer. The last thing I tried was hitting the find my Garmin alert and everything went back to normal. No…
Just got the same issue. I kept the side-button pressed a long time and it powered down. Something like 10 seconds or more. I was actually reading this article and didn't notice it finally powered down…
Thank you! "find my device" worked for me as well
As others noted, no button on the vivosport (at least older gen). Again, Garmin should set up a button in the Connect app to restart the watch. Simple fix that should resolve a lot of issues. @Garrmin happy to test this feature out for you
This one is the method which I have tried and got mine fixed.
