Watch faces from connect IQ not working
Hey,
Is anybody having any issues with watch faces downloaded from connect IQ not working since the update last week? was working fine then my watch updated and any downloaded face I have just gives an error icon in the watch face selection screen.
  • To me it seems that the problem is not with the watch faces or the firmware per se, but rather the way widgets address memory when getting a GPS lock since firmware 6.90. I've done a lot of testing, with a dozen watch faces and even more widgets. Only when I use third party widgets which use GPS data do the watch faces crash. Garmin's own widgets, even those from the IQ Market, are OK. Also when third party widgets use stored GPS data from an activity everything is ok. The moment any third party widget gets a GPS fix, I get the infamous IQ! error. So I think something changed in firmware 6.90, and the developers haven't updated their widgets. Please remember that the developers have to keep a large number of firmwares in mind, not just the one for the VA3. These errors might also not appear in the emulator. It's up to Garmin to publicise any change in the firmware.
    0 Former Member in reply to Bernard F
    I'd suspect something in this direction as well. But simply adding here that in my case even Garmin's own watch face from IQ market didn't work...
    Btw, possibly not related but with the software update to 6.90 my step counter started misbehaving as well (counting about 2-3 times fewer steps in normal mode, everything's fine when starting a walking/running/.. activity). I suspect something around power saving there but haven't yet got the chance to start looking for any solutions..
  • Sure, Garmin watch faces also get corrupted if a third party widget isn't optimised. But Garmin widgets play ball with all watch faces.
    Thanks for pointing out the step counter issue! I thought I was getting lazy... Slight smile
    Same, i had maybe one that installed rest just sitting in queue
    Same, when garmin resolving this. They just sit in queue...
  • There's been a Garmin IQ Connect Update, and since then I've had no further crashes. I'll  keep an eye on it and will report back to you. Keeping my fingers crossed....
  • Ok, here's what I've found so far: the IQ update didn't do much. Widgets which take their location info from activities are OK, provided you have recent GPS data. Widgets which make a GPS lock at startup crash the watch faces. Garmin widgets are ok.
    Same this morning my watch face is gone and i only have a few analog type to choose from.  the IQ circle has a ! in yellow circle and will not display previous installed watch faces.
    0 Former Member in reply to Former Member
    Just Power Of Your watch And Switch it back On
