How are your experiences with the battery of the Venu? I am really excited about the watch but there are a lot of complaints on the new vivoactive when it comes to the battery. Is ist the same with the Venu?
I had battery drain giving only 2 to 3 days use, with no activities, using CIQ watch face whilst on firmware 3.8.
Deleting the CIQ watch face and using a built in watch face didn't initially reduce the…
So here is my experience. For few weeks ago the battery life was very poor due to prevoius updates, but after 4.0 software update It is much better, but I think there is still some problems. After this…
I'm still getting low battery drain, but have been trying a few things to see the impact on battery life.
I set up the Venu as follows
BT 24/7 ‐ I use the Venu as a trusted device on Android and have…
Thanks everybody! Got mine yesterday and went from 100 to 83 in 27 hours with lots of usage, setup and a workout! I think this is great!
I had no problem with battery life on my first Venu with FW 3.40. It lasted around 4 days WITH ALWAYS ON DISPLAY.
But I had to return it for a new one because of a defect (no vibration). The new one works good but with FW 3.50 installed it lost 30% in only ONE NIGHT! Weird. With the first Venu I lost that amount of battery in 1-1.5 days. I hope it's not a defect again.
Which watchface do you use whith always on?
With the first Venu device I used Crystal from ConnectIQ. It worked perfectly. and had good battery life. Till now I used Garmin Digital clock and no always on during night in sleep phase. So no always on during night. Now I use Crystal again with my second device. Great watch face. Always On display moving which I think is better because of burn in possibility. Garmin's always on watchfaces don't move at all. And always on display is quite bright.
Battery drain on my Venu has varied enormously, especially after firmware update 3.8. Now on 4.0 and battery drain is much better.
I have Bluetooth all day, pulse ox at night, no wifi, no music and use a built in analogue watch face.
Battery drain, no activities, is now just under 12% per day.
Battery drain, for a GPS enabled activity, is less than 6% per hour.
Based on the above figures the battery should last up to 8 days with no activities and 5 days with 1 hour of GPS enables activity per day.
This is much better than anything I achieved with my VA3.
I have tried a few CIQ watchfaces, including on firmware 4.0, but so far find the battery drain is significantly worse and the display is slow to turn on from a gesture, around 2 to 3 sec delay. For these reasons I have stopped using CIQ watchfaces. Not a problem for me as I like the built in analogue watch face.
As with all these gadgets, YMMV
